Difference between Radius and Tacacs enable mode ?
jazzzz
Community Member
I'm switching from radius to tacacs authentication via ACS3.2. Previously when i'm using radius, going to previledge mode uses the default $enab15$ as the username.
Now when i configure using tacacs, i'm unable to go into previledge mode. It will prompt for authentication error. Just wondering if tacacs also uses $enab15$ to go into previledge mode ?
Any advise on how to configure tacacs previlege mode?
Tks !!
===== My tacacs config =====
aaa new-model
aaa group server tacacs+ SW_Tacac
server 10.90.3.106
tacacs-server host 10.90.3.106
tacacs-server key 8888
aaa authentication login SW_Tacac group SW_Tacac local
aaa authentication enable default group SW_Tacac line
aaa authorization network SW_Tacac group SW_Tacac local
aaa accounting network SW_Tacac wait-start group SW_Tacac
line vty 0 4
exec-timeout 0 0
login authentication SW_Tacac
ovt
Level 8
Level 8
No, T+ doesn't use $enab15$. You can configure separate enable password and max privilege level per user. Enable Advanced T+ Features under Interface Configuration and configure this in User Setup.
