Help in research : BYOD and Any Connect
PiCar
I have read through various articles and posts but looking for some clarification please;
Could I to allow a BYOD devices (laptops/tablets), to use Any Connect but prior to using Any Connect, could the device be checked for a certain specification, such as a Windows device is running Windows 10 to a minimum specification of, lets say 1909?  Also, for the device to have a form of antivirus installed that is up to date?
I don't know if this is correct, I shall ask anyway, as I won't learn anything if I don't ask;
How would all the above work with the ISE (Cisco Identity Service Engine), to check through Host Scan to see whether the posture of the device is running adequate security as proposed as minimum security settings to run the Cisco Any Connect – how does Terminal Access Controller Access-Control System fit into Any Connect?
Thank you in advance for your help :-)
2 Accepted Solutions
Mark Elsen
 https://community.cisco.com/t5/security-documents/ise-posture-prescriptive-deployment-guide/ta-p/3680273
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mike.Cifelli
On top of the link provided. Here is another area with free tutorials that should be able to assist you in configuration your configuration journey: http://labminutes.com/sec
-With the posture module you can check for them items that you have mentioned. Some checks to meet those requirements could be the following:
Cisco has pre-built registry checks that can be utilized to determine what OS version. Or you could specifically create your own registry check to determine exact version such as:
Registry Condition: OS = Windows 10 (all); HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\CurrentBuild String EQUALS <18363>
Another example could be to ensure you have McAfee agent running: Service Condition: McAfee Agent; OS Windows 10; Service Name EQUALS masvc; Service operator EQUALS Running
There are a plethora of things you can target to determine posture status prior to onboarding to include specific matches on AV versions. I recommend taking a peek at some of the tutorials & the guide provided to gain a better understanding of the overall workflow. Good luck & HTH!
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you for the link :-)
Mike.Cifelli
Thanks for that, it was really useful :-)
