(HELP) Integration ISE 2.1 With Aruba WLC 3200
aship.barkiya48
I,m trying to integrate ISE 2.1 to WLC Aruba 3200 but i have some problem,Authentication Successful when i test via CLI in aruba WLC
but in ise showing this error
error:5440 Endpoint abandoned EAP session and started new
can anyone help me?
Craig Hyps
Level 10
Level 10
Ashif,
I recommend open a TAC case to help resolve.  Too little information is provided above to quickly get at root of issue.
Be sure to review the 3rd-party integration guides for Aruba here ISE Design & Integration Guides
This one in particular should help: How To: ISE Integration with Aruba Wireless Networks
You may also want to see our Third Party NAD Profiles page which has an example Aruba-7005-NAD-Config
configuration.
For ArubaOS versions > 6.4.2.5 you may need to update the NAD profile with the following:
     Service-Type for MAB = "Call-Check"
     Service-Type for 802.1X = "Framed"
Craig
Craig Hyps
Level 10
Level 10
Ashif,
configuration.
Craig
