How To Configure Posture with AnyConnect Compliance Module and ISE 2.0 without ASA involved
refaatcisco1234
paul
Level 10
Level 10
What do you mean without ASA involved?  Do you mean VPN posture but not using Cisco VPN head-end?  If so, then you should update ISE to 2.2 or later and use the non-redirection methods for posture.
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/210523-ISE-posture-style-comparison-for-pre-and.html
Nidhi
ASA is not needed for Posture services.
you can refer Posture deployment guide here - https://community.cisco.com/t5/security-documents/ise-posture-deployment-guide/ta-p/3680273
Nidhi
