How to integrate ISE 2.4 with SMS gatewat for guest flow
dgaikwad
Level 5
Level 5
Hi Experts,
I want to integrate SMS gateyway for guest flow, but the documents that I am able to find mention about ISE 1.4.
Are the steps for ISE 1.4 and 2.4 the same, or has there been an updated document available out there?
Any pointers, much appreciated
Thank you,
The concept and GUI are mostly same. I would recommend looking at sms section under http://cs.co/ise-guides
The documents are not updated to reflect slight changes in GUI
balaji.bandi
Almost all same may be gui changed as per i know..
here is the latest document (make sense ?)
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_01111.pdf
I have attached one of the good document i used some time back to intergrate with ISE, it was very helpfull to understand, may ne not relavent not sure. but good to share here. if any one interested.
BB
Thanks for pointing to this document.
It does have the configuration information that I have been looking for.
Will test it out and see what are the results I get.
Yeah, that was one of the reasons I was looking for an updated document.
But, was able to navigate and find the right menus and settings.
I think this will work for now.
