ISE and wireless CWA
Need some help on this one.
This is ISE 1.1.1 and WLC 7.2
I want to use CWA and Webauth for guest users, and I have configured that on the ISE and WLC.
This is working but I need some clarification :-)
First I tried to use AuthC policy with
allowed protocolls= PAP-ASCII + Host lookup
Result of that was that for Mac OS X an MS PC it's no problem, I get redirected, logon, press yes on the AUP and I can go on surfing the web.
But on the iOS devices I get redirected to the guest logon page, put in my credentials and insted of the AUP page I get a network error, could not connect.
If I change AuthC to
allowed protocolls=  Default Network Access
All is working fine for all endpoints.
Im looking at the RADIUS Authentication Details but I dont understand what iPhone/iPad do diffrent?
An other question here, can I get a redirect after successfull logon instead of 'Please retry your orginal URL request'?
Thanks!
5 Replies 5
Tarik Admani
HI,
Can you please provide a screenshot of your authorization rule.
As far as redirection, it is ISE that redirects the user and there is not a way around this (because of the redirect acls...etc). You can check with TAC but I dont see a way where you can redirect users to a url after they authenticate via CWA.
Tarik Admani
*Please rate helpful posts*
I did solv this (sort of) using html redirect on a custom portal, going to the customers web page.
http://www.cisco.com/">
It would be nice to have a redirect to the page the user wanted to view prior to login but this is good enough
Ho Mikael
I am looking for this feature as well. Did you find out how to set the original URL redirect instead of a custom webpage?
Cheers Marco
Hi Marco,
It's not possible in this releas of ISE, v1.1.x.
Only the redirect with html code.
BR
Mikael
