ISE appliances go to standby power mode after power failure reboot
s.rashid
we have two node deployment of cisco ISE. We usually face power disruption in our data center and because of that servers and appliances reboot. we have noticed that cisco ISE and other cisco appliances like WLC, collaboration appliances, go to standby mode (power LED color changes to amber) once the power is back and the appliances reboot. we have to manually power on the appliance by pressing the power button. we need your support to suggest us the solution so that the ISE appliances reboot to fully functional and do not go to power standby mode once reboots due to power failure.
Hi @s.rashid ,
 as @Leo Laohoo said ... please take a look at: Cisco UCS-C Series IMC CLI Configuration Guide or Cisco UCS-C Series IMC GUI Configuration Guide, search for Configuring the Power Restore Policy.
Hope this helps !!!
Leo Laohoo
It is the default behaviour and can be changed in CIMC.
Hi @s.rashid ,
Hope this helps !!!
