ISE (Identity Services Engine) 2.2 Doesn't save network device profiles settings
license_fgce
Good day. I am trying to add a custom network device profile.
The profile is created but settings are not saved inside it. (See attachment)
Does anyone know how to solve the problem?
My account is in the superadmin group.
ISE
Version:
2.2.0.470
Patch Information:
5,9,10,12
Installing patch 16 solved the problem
poongarg
This is the known defect on ISE 2.2 P12:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn75254
It is fixed in ISE 2.2 P14.
poongarg
Thanks for your reply.
I'll go update =)
In case you're not aware, I just wanted to add that ISE 2.2 has passed the End of Routine Maintenance milestone as per this Product Bulletin. You should strongly consider upgrading to a newer version for future support and longevity.
