08-06-2020 10:13 PM - edited 08-09-2020 10:48 PM
Identity Services Engine
Solved! Go to Solution.
08-07-2020 09:17 PM
This is the known defect on ISE 2.2 P12:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn75254
It is fixed in ISE 2.2 P14.
08-07-2020 09:17 PM
08-09-2020 06:53 PM
08-09-2020 07:26 PM
In case you're not aware, I just wanted to add that ISE 2.2 has passed the End of Routine Maintenance milestone as per this Product Bulletin. You should strongly consider upgrading to a newer version for future support and longevity.
