ISE Machine Cert Authentication Issue
fatalXerror
Level 7
Level 7
Hi Guys,
I have issue right now about EAP-TLS computer authentication, the ISE is rejecting the authentication and based on the ISE logs,
"12514 EAP-TLS failed SSL/TLS handshake because of an unknown CA in theclient certificates chain"
I checked the certificate-chain of ISE and the certificate-chain of the endpoint, all matched but still the ISE is rejecting it and showing that failure reason.
Any idea how to resolve this?
Thank you.
Hi @fatalXerror
 please try to perform a manual Synchronization between the Nodes (Administration > System > Deployment) ... take a look at: CSCux69800 ISE 2.0 / EAP-TLS: unknown CA in the client certificates chain.
 Note: also take a look at an old bug: CSCtq31131 Sometimes need to delete some trust certs for the required certs to work (sometimes the Root and Intermediate CA are not properly imported into ISE and you must delete and re-add).
Hope this helps !!!
Hi, may i know how can I do a manual synchronization? Thanks
 at Administration > System > Deployment > select a PSN > and click Syncup:
Hope this helps !!!
