ISE power Supplies check
armina.emad1
I have ISE appliance with dual Power Supplies is there any way CLI or GUI to check if there is a failure in any one of them ?
andrewswanson
Level 7
Level 7
The appliance CIMC is the tool to use for this.
hth
Andy
andrewswanson
Level 7
Level 7
hth
Andy
Arne Bier
Here from CIMC - CLI will of course give same result
Damien Miller
I would like someone to attempt to monitor a physical SNS ISE appliance with Cisco Intersight. I do not have any available to me to try this with. While there is no support stated for non UCS SKU's, SNS appliances are after all just UCS C220's under the label. The free version provides remote hardware monitoring relaying on the CIMC 3.0(4)+ software. If it doesn't work, it would be a great feature request for a free(limited features) UCS management platform.
