ISE Problem
Reyad Safi
Level 2
Level 2
Hi Experts
we have new ISE servers at our network and it work good .
but lately i faced the below problem :
the ISE integrated to get the authentication from the microsoft active directory which depend on the windows login username / password , and the dot1x configurations and settings pushed to the users PCs via the active directory and the user can't change it .
if the user login to the windows sucessfully , the ISE put the user in the quarantine vlan , then check the policy and if pass assign the full access to the users .
Our System Admins force the users to change the password monthly bases , so when the password expired , the authentication failed so the ISE will not assign any vlan to the user , and the can't change the password on the Active Directory becouse he is disconnected from the network .
so i need a way to enable the switch to assign a restricted vlan to reach the Active Directory once the user plug the network cable , regardless he authenticate succesfully or not .
our switch configuration is :
aaa new-model
aaa authentication login default local
aaa authentication login TEST group radius
aaa authentication enable default enable
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa server radius dynamic-author
client 10.10.10.238 server-key C1sc0
aaa session-id common
system mtu routing 1500
authentication mac-move permit
ip device tracking
interface FastEthernet0/2
switchport access vlan 22
switchport mode access
switchport voice vlan 110
authentication port-control auto
mab
dot1x pae authenticator
spanning-tree portfast
ip access-list extended ACL-POSTURE-REDIRECT
deny   ip any host 10.10.10.238
deny   ip any host 10.10.10.239
deny   udp any any
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq 8443
ip access-list extended webauth
ip radius source-interface Vlan10
ip sla enable reaction-alerts
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 20 tries 3
radius-server host 10.10.10.238 auth-port 1812 acct-port 1813
radius-server host 10.10.10.239 auth-port 1812 acct-port 1813
radius-server key C1sc0
radius-server vsa send accounting
radius-server vsa send authentication
aaa new-model
ip device tracking
mab
deny   udp any any
any suggestion to solve this problem .....
regards
Reyad
10 Replies 10
Tarik Admani
Reyad,
Please check and see if you have the enable password change box enabled under your AD settings:
http://www.cisco.com/en/US/docs/security/ise/1.1/user_guide/ise_man_id_stores.html#wp1243634
Tarik admani
Dear Tarik
thank you for your reply , but it's already enabled there ...
i think i should add some configuration or ACL to the switch to assign native vlan to the port before checking the authentication from the AD .
Any Suggestion
Reyad
Reyad,
The password change is done through the supplicant and over to ISE via peap-mschapv2, there is no need for the client to be connected to the domain in order to do the password change. What version of ISE are you currently running?
tarik Admani
Dear tarik
Version Identifier (VID)  V01
ADE-OS Version  2.0.2.103 Version Identifier (VID)  V01
the above reply not clear for me , please clarify it more , how could i change the AD Password while im not connected to the network ? please advise .
the PC IP address when it not authenticated succesfully is nubian ip address ( 169.x.x.x)
Reyad
That is normal, dot1x works as a L2 authentication mechanism in which radius from the NAD to the radius server is encapsulated in a radius packet. If authentication fails then the client doesnt receive and ip address since dhcp isnt forwarded from the NAD.
I need you to issue a show ver from the cli.
Also can you post the screenshot of the authentication to see why the client is failing, is it because the password is expired or is the account locked out? That will make a difference too.
Tarik Admani
the Sho Ver from cli is :
ME-ISE-1/reyad# sh version
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.2.103
ADE-OS System Architecture: i386
Copyright (c) 2005-2011 by Cisco Systems, Inc.
All rights reserved.
Hostname: ME-ISE-1
Version information of installed applications
Cisco Identity Services Engine
Version      : 1.1.0.665
Build Date   : Thu Mar  8 00:51:03 2012
Install Date : Tue May 22 10:39:15 2012
Cisco Identity Services Engine Patch
Version      : 1
Install Date : Thu Jun 21 10:47:35 2012
and i will provide you the GUI screenshot when available .
thank you for support
Reyad
Reyad,
My apologies for the delay were you able to get this resolved?
Tarik Admani
*Please rate helpful posts*
Dear TArik
thank you for your interesting ...
i solved the problem , and every thing working now
Reyad
Could you please share how you solved your problem?
Thank you.
Hi Edondurquti
yes you are right .....
i changed the authentication method from user authentication to computer authentication , so when you plug the network cable to the PC , it start authentication and the ISE assign the quarantine vlan to the port , so the changing password problem solved .
the computer authentication solved many problems i faced when implementation .
-     when you try to connect remotly to your PC at the office ( when i applied user authentication ) , it was
connected for seconds , then the PC re-authentiate and assigned to the quarantine vlan , so i lost the connection to my PC .
-     the password expire problem happened on the user authentication especially when you put the option to use the windows login .... its big problem .
-     many PCs can connect to the network using the same username/password ,,, and this is also big problem .
-     no way to enforce the users to join to the domain if you use the user authentication , you can login locally at your pc , then at the popup screen you can enter the AD user .
by using the computer authentication , all the above problems solved , and the connection become more stable , and all PCs enforced to join to the domain to get the authentication.
another helpful command on the switch , is to assign a restricted configured VLAN to the switches as native VLAN , and you can apply the below command on the interface to assign a VLAN when the authentication fail .
Switch(config-if)#authentication event fail action authorize vlan
i hope this can help you in case you faced the above problems ....
Reyad
