ISE specific interface for Device Admin operation
Hi all;
As far as I know, ISE by default supports RADIUS-based traffic in all interfaces (interfaces other the Gig 0). I want to know that, is this rule also applies for TACACS traffic?
Hi @rezaalikhani
ALL Interfaces can be configured with IP Addr.
RADIUS and TACACS+ can be performed on separate Interface, but listen on ANY Interface.
Guest/Sponsor/My Devices/BYOD Portals can be configured and restricted for specific Interfaces.
ISE management is restricted to GigabitEthernet 0.
Hope this helps !!!
balaji.bandi
It's the same case with TACACS, too, as far as I know; if you like, you can use a dedicated interface depending on deployment; make sure you have a high availability setup.
https://www.cisco.com/c/en/us/td/docs/security/ise/3-0/install_guide/b_ise_InstallationGuide30/b_ise_InstallationGuide30_chapter_7.html
BB
Hi @rezaalikhani
Hope this helps !!!
