MANAGEMENT INTERFACE IN ACS1121
muhammad feroz
Dear all
I am trying to configure the Management interface on Cisco Acs 1121. when i type show run
I can only
Gigaehernet 1
Gigaehernet 2
Gigaehernet 3
Gigaehernet 4
but i can not able to see the Management interface
as you know that if you see Cisco ACS Back Panel it has 4 X Gig interface and 1 Management., I would like to configured the ip address on Mangement interface.
At the moment i have configured the ip address on Gig 0 , i can able to access ACS via Web interface.
Do i need to update the IOS in ACS device to configure the Management Interface. please answer asap. very urgent. Please look at the attachment.
because they can't make changes in the hardware everytime, for the rest of the interfaces they are working on it (acs codes) and will put more funtionality in future codes to support new feature by using these intefaces.
don't forget ACS 5.1 is very young, there are N number of new features are lined up for this product.
Regds,
Jatin
Do rate helpful posts~
~Jatin
12 Replies 12
You can only use the first gigabyte ethernet interface, the rest are not supported by ACS5.
Thanks for your reply.
can you let me know exactly which version does support the management interface and
any link which will explain the Update process.
Thanks for your quick reply.
Message was edited by: muhammad feroz
Currently i have 5.1 version in my Cisco ACS 1121 appliance.
Can you let me know exactly which version does support Management Interface on Cisco 1121 appliance
and any link which explain the update process.
Only Gigabit Ethernet 0 is supported, rest all ports are blocked, this is not gonna work by upgrading the software or firmware.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_hw_ins.html#wp1119105
Jatin
Do rate helpful posts-
~Jatin
Dear  Katyal
Thanks for your reply,
1. i just want to know if the interfaces are blocked, than why cisco company added those interfaces?
2. actually i need at least 2 interface ->   one for management and 2nd for Live network,  Is there any other appliance which support 2 interfaces.?
3.so, you menat to say that In the ACS 1121  there is no chance i can get 2 interfaces.?
Please reply to my questions. thanks for your help.
Regds,
Jatin
~Jatin
Dear Katyal
Thanks for your reply &
Conclusion :
Cisco ACS 1121 In 5 interfaces (1 x management & 4 x network interfaces)
it support only 1 interfaces which is E0.  it does  not support 1 x management and 3 x rest of network interaces at the moment.
May be in future it may support.
Please reply to this email, what i menionted is correct or not?
Your understanding is correct.
Rgds, Jatin
~Jatin
Hello Friends,
I am installing new ACS 1121 and found same thing, does anyone knows does ACS 1121 supports mgmt interface now oe still it only supports only eth0 interface.
Please confirm asap. Thanks.
Ajay
ACS versions 5.0 up to 5.3 only support one interface, regardless of how many are present on the appliance.
Thank you very much. It was really quick, I was wondering they why Cisco is providing so many interafces with BOX in case we can not use them, It is just creating confusions ?
Also I am installing new appliance Cisco 1121 and wanted some basic configuration help using which I can wuickly configure the basic things like backup logging n all. In case someone has quick guide, it will be really nice for me.
Ajay
Hi Ajay,
  Here is the link that you can follow: It has some common scenarios.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/common_scenarios.html
Here is the link that you can refer for backup
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/admin_operations.html
- for logs you can go to reports and monitoring> catalog> aaa protocols> click on any of the following>
radius authentication
radius authorization
tacacs authentication
tacacs authorization
similarly options are available for accounting as well.
Let me know if it helped
Minakshi
