Memory problem with ACS 2.6 and CSLog
tsybille
We're using ACS 2.6 with logging to and ODBC database, and with the time, the memory rapidly fill-up (+/- 40 MB/day). The process that get the memory is CSLog.
Does anyone have the problem ?
Thierry Sybille
lisa.hall
Level 2
Level 2
Is the machine crashing because of a memory problem? Can’t the ODBC database server keep up? Please clarify and I’ll try to help.
The machine stop responding after a moment because the entire memory is full (512Mb). At this moment, the CSLog process take +/- 400MB. If I stop and restart the process, the memory load drop near 110 MB and the machine is responding again.
The odbc database is redirecting to and SQL serveur which have no performance problem.
Thank's for your help
Hmmm….that’s an odd problem. I’ve seen similar issues where the logging server simply is not powerful enough to keep up and the buffer overflows the available memory. It would be a good idea to check that first, maybe test with a faster server.
