NEAT Network Edge Authentication Topology
hdussa
i´m using ACS5.5. NEAT work fine. Is there a possibility to add a command when the port changes from access to trunk? Because cdp is not enabled when it is an access port. But when it changes to trunk i would like to enable cdp.
Jan 17 11:39:09.922 CET: Applying command... 'no spanning-tree bpduguard enable ' at Gi0/3
Jan 17 11:39:09.938 CET: Applying command... 'no switchport access vlan 998' at Gi0/3
Jan 17 11:39:09.989 CET: Applying command... 'no switchport nonegotiate' at Gi0/3
Jan 17 11:39:09.997 CET: Applying command... 'switchport trunk encapsulation dot1q' at Gi0/3
Jan 17 11:39:10.014 CET: Applying command... 'switchport mode trunk' at Gi0/3
Jan 17 11:39:10.039 CET: Applying command... 'switchport trunk native vlan 998' at Gi0/3
Jan 17 11:39:10.047 CET: Applying command... 'spanning-tree portfast trunk' at Gi0/3
        cdp enable                                                  <----- that is what i want to add
Horst
marc.groenen
Im also looking to add some commands to the "template" the ISE pushes to the port.
Maybe a switchport trunk allowed vlan list and such
The implementation i have is a Cisco ISE 1.3.
Did you manage to solve this ?
