Need help on NAC for VPN
User_80617
Hello Guys, Need you help. This will be a long post and i need help in deployment of NAC for vpn users.
Requirement is user shall connect to vpn post some checks that defined on Cisco ISE.
1. What config needed on Cisco ASA
2. What config needed on Cisco ISE
3. Any config related to hostscan, posturing needs to be on Cisco asa?
Need suggesting on parameters to test and things to ensure before rolling out in production.
3 Accepted Solutions
Hi @User_80617
 at Operations > RADIUS > Live Logs, check the Authorization Policy of this particular Identity (user).
 Use this information and double check at Policy > Policy Set if it should be the correct Authorization Policy.
Hope this helps !!!
Compliance module says no policy server detected and user gets access even after required components missing on his endpoint.
-This is typically because your module is missing the respective posture profile xml files.  The URL redirect should point a new/unprovisioned client to your portal in which ISE will then push down your configured profiles/modules/etc.  Another option you could test is manually adding the profiles to your test client.  I suspect this may be a missing piece as well as how you have your client provisioning portal setup.  That guide shared definitely covers the necessary steps involved.  However, its screenshots/demos are from a very old version of ISE.  I would suggest taking a look at some lab tutorials from links already shared in this post as well as having a look here: ISE Posture Prescriptive Deployment Guide - Cisco Community
HTH!
Hi @User_80617 ,
 you are able to use the Conditions:
Cisco-VPN3000-CVPN3000/ASA/PIX7x-Tunnel-Group-Name equals <Tunnel Group>
or/and
DEVICE.Location equals All Locations#<Location>
Note: remember to add your ASA to the <Location> at Administration > Network Resources > Network Devices.
Hope this helps !!!
10 Replies 10
@User_80617
Here is the official Cisco ASA RAVPN and ISE Posture guide, this covers the ASA and ISE config.
https://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/117693-configure-ASA-00.html
You don't need to use Hostscan if you are doing posture on ISE.
Hi.. Thanks for revert. But, this didn't work.
Hi @User_80617
Hope this helps !!!
below were the live logs output
11001 Received RADIUS Access-Request
11017 RADIUS created a new session
15049 Evaluating Policy Group
15008 Evaluating Service Selection Policy
15048 Queried PIP - Network Access.NetworkDeviceName
24715 ISE has not confirmed locally previous successful machine authentication for user in Active Directory
15036 Evaluating Authorization Policy
24209 Looking up Endpoint in Internal Endpoints IDStore - xxxxx
24211 Found Endpoint in Internal Endpoints IDStore
15048 Queried PIP - Session.PostureStatus
15016 Selected Authorization Profile ASA-Posture
22081 Max sessions policy passed
22080 New accounting session created in Session cache
11002 Returned RADIUS Access-Accept
Authorization Policy Posture_Policy >> Posture_Unknown
Authorization Result ASA-redirect
ASA_redirect should direct user to ise but compliance is failing. Even posture unknow status shall get access rejected (Access Type = ACCESS_REJECT) but user can successfully connect to vpn.
What could be wrong. Followed the cisco config document as it is.
Hi @User_80617
 at Policy > Policy Elements > Results > Authorization > Authorization Profiles > select the Authorization Profile that you use in your "Unknown Policy Set" and at Common Task, double check your Web Redirection configuration.
 Double check if the name of the ACL (located on the Web Redirection configuration) must exist on your ASA.
Hope this helps !!!
HTH!
The posturing now works ok. but i have 2 queries.
1. It works only when the ise -posture/compliance module is installed on the system. In case when connected from a system having only anyconnect client, vpn gets connected.
2. What should be settings on cisco ise, if i want to apply the posturing, client provisioning only for a certain vpn profile on a perticular asa (there might be many other profiles coming to ise for authentication)
Need some help on this.
Hi @User_80617 ,
or/and
Hope this helps !!!
balaji.bandi
This not just few steps, this required some kind of integration expert to imlement things in step by step approach - no from day 0.
you need put some time and understand how these each components works,
https://community.cisco.com/t5/security-documents/nac/ta-p/3114257
here is some resource to start with :
ISE Community Resources
http://cs.co/ise-resources
YouTube Channel: http://cs.co/ise-videos
Integration Guides: http://cs.co/ise-guides
BB
Mike.Cifelli
Also, take a peek at https://labminutes.com/video/sec
Good free tutorials there.  HTH!
