NOT ABLE TO RESTORE Cisco ACS BACKUP in 5.3
Sakthi vel
Dear All,
I created Repository in ACS and trying to restore the backup file of 40 MB from FTP Server
Getting the error "% Failure occurred during request "
But I'm able to restore the file size of 12 MB
Note : The file which is failing is taken from the another production server 5.3.40.8 and trying to restore the same in my testing environment 5.3
Is there any file size restriction is there.... Please help on this.
18 Replies 18
Let's take out sometime and check your setup. Please contact me on gmail.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
we were using a command "backup" to take ACS backup. Suggested you to use "acs backup" and it worked.
Command reference.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/command/reference/cli_app_a.html#wp1886805
~BR
Jatin Katyal
~Jatin
Hi Sakthi!
This worked for me thanks a lot!
Lawrence Ong
Hi all,
i encountered the same error using 'acs restore'.
is there any solution for this?
what is file size restriction?
