Pane is dead signal 7 error of ISE installation in Cisco SNS 3700
dil2
Hi we are installing ISE 3.3 on a SNS3715 server. i have connected to KVM console on the web browser by connecting to the dedicated management port. I have saved my ISO file in my laptop and created mapped virtual drive mKVM-Mapped DvD by selecting local ISO file in my laptop. selected option for ISE installation using keyboard and mouse. after 2 hours running the installation, I got "pane is dead signal 7" error message. anyone got this similar issue and a way to fix this please.
Arne Bier
It's possible that the ISO is corrupted. Have run an MD5 checksum against it on your laptop?  On Windows you can do this in powershell
certutil -hashfile Cisco-ISE-3.3.0.430.SPA.x86_64.iso MD5
According to software.cisco.com it should be 4bd259c5fb63bb0e089e690be8817043
Hi Arne, yes. I did check this against the value we see in download portal.
Arne Bier
That seems to be a Linux kickstart error message - just searching the web didn't find a conclusive answer - but in a situation like this, where the SNS server is a black box, there is no reason for a simple install NOT to work. Did you fiddle around in the BIOS or CIMC at all?  I'd open a Cisco TAC case.
davidgfriedman
We used to have this happen a lot when we had SNS-3695-K9 and SNS-3655-K9 units. When we opened Cisco TAC cases for it, I swear they told us it was something related to network timeouts specifically related to those models.  Since you're running SNS-3715-K9 (if I read your post correctly), then it isn't just a problem for 3655 models.
I read you're using Web console. Have you tried:
a) switching to the java console, as their mount supposedly transfers data far faster than the web console?
b) using a pc or server closer (fewer hops away) from your SNS-3715-K9 appliance?  Ours was a data center away.  We tried a VM with a browser which was in the same data center and it worked a bit more reliably.
FWIW, we still prefer using USBs we burned (and edited the files to fix the "cdrom" vs "hdXXXXX" load line.  The USBs could re-image in an hour then get to the setup login, whereas over the web console / java console it could take anywhere from 4-12+ hours.
David
