PEAP and MSCHAPv2 authentication with LDS (ADAM) using Cisco ACS
Jesse Zepeda
Level 5
Level 5
We have a Wireless LAN controller that needs to do PEAP/MSCHAPv2 to a LDS aka ADAM server.  Is this possible using Cisco ACS?
Amjad Abdullah
It is possible to do the PEAP/MSCHAPv2 using cisco ACS.
But the point I don't understand is the LDS/ADAM you mention is it a AAA client (a device that users try to reach) or a AAA server (a server that tells the users if their auth passes or fails)?
Please explain the scenario and how (and why) the server uses the PEAP? to authenticate itself? or to authenticate users connecting to it?
Amjad
Rating useful replies is more useful than saying "Thank you"
tarv1s1umacelum
Hi Jesse,
have you finally found  a solution for this problem?
I've the same difficulty with ACS 5,6
Thank you
jan.nielsen
Level 7
Level 7
As far as i know LDS only uses LDAP, LDAP does not support MSCHAPv2
