Bookmark
Subscribe
1609
Port Forwarding ISSUE on Cisco ASA 5545
Respected All;
I have purchased Cisco ASA 5545 in which i have created sub-interface with security level 100 on inside network where as outside interface also configured with functional status. All traffic works well from inside sub-interfaces to outside.
The Problem is that when i want to port forward from outside interface to inside sub-interface firewall reject it and not forwarded the traffic to internal machine.
ALL Natting and ACL also configured fine and also compared with cisco documentation i dont know why this is happening to me.
Kindly Help Me.
9 Replies 9
Damien Miller
Leveraging the packet tracer functionality could be a huge help for you here. If it is a config issue then it should indicate which step along the way is causing the drop.
object service Port-forward-real
service tcp source eq 3389
service tcp destination eq 9001
nat (vl215,vlan301) source static 192.168.215.37-32 Public IP service Port-forward Port-forward-real
access-list outside extended permit ip any host 192.168.215.37
I have configured above mentioned config on firewall, How can i use packet tracer to find actual problem
FW-SIBA-5545#packet-tracer input vlan301 tcp 192.168.215.37 3389 PUBLIC IP 9001
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop PUBLIC IP using egress ifc vlan301
Result:
input-interface: vlan301
input-status: up
input-line-status: up
output-interface: vlan301
output-status: up
output-line-status: up
Action: drop
Drop-reason: (nat-no-xlate-to-pat-pool) Connection to PAT address without pre-existing xlate
ALL NAT Process Seems ok from Inside to outside and all traffic like internet browsing etc are working fine.
But when i will try to port forward form outside to inside its create issue
Need Expert Advice and support Please
I may be miss understood here, you looking to NAT from outside to inside right ?
Assuming that the server is: 192.168.215.37, and you woud like to NAT it to PUBLIC-IP.
BB
No Sir,
I need to Open 3389 Port for this machine which is 192.168.215.37
Its Port Forwarding Like Outside to Inside
So rule is like below
user connect to Public IP - 9001
you want to port-forward to internal IP 3389
Is this Public-IP shared or Dedicated ?
BB
Public IP is dedicated Sir
Sir is it some kind of bug because i have tried a lot from last 9 days but i dont why this firewall is behaving like that
