Power specification for ISE 3515
Akshaya Kumar Sankaran
Hi ..
Need some help on following Power requirements for ISE 3515 appliance
  • Equipment Power Usage - Typical (W)
  • Equipment Power Usage - Max (W)
  • Input Power (VA)
  • Rated Power Supply Max Output (W)
  • Supply Efficiency
Thanks.
~akshay Technical Marketing Engineer Broadband SP WiFi Mobility IPv6 CCIE SP#28296 sakskuma@cisco.com
hslai
ISE 3515 is based on C220 M4 and uses 770 W AC power supply
Cisco UCS C220 M4 Rack Server Technical Specifications
Table 45 shows
hslai
Table 45 shows
