problem, with acs services
Ibrahim Jamil
Level 7
Level 7
Hello Folks
I Have acs 4.2 installed on windows server 2003 , however the domain controller is windows 2008 64bit edition
the acs is patched with last patch for windows 2008 64bit edition ,witch is (15)
the acs is successfully integrated with ms AD as single sign on
in wireless i m using 802.1X based PEAP,the acs has certificate installed like self signed certificate ,but i face problem when i enabled the EAP-MSCHAP,the service stopped after check the EAP-MSCHAP , then i no longer able to start the service and even from windows service
after i uncheck the EAP-MSCHAP then i able to start the service again
which one of these are the new for win dc 2006 based 64bit
Release 4.2(0) Build 124 Patch 13
or
Release 4.2(1) Build 15 Patch 4
plsese help
Hello Ibrahim
The latest ACS patch for win 2008 64-bit is Release 4.2(1) Build 15 Patch 4.
When you enable "EAP-MSCHAPv2" on ACS server, the service stop. Did you see any error message after enabling it ? What is the status of services on event viewer ? They are in "starting" / "stopping" status ?
thanks
Devashree
hi
no errors when y enable it
the status is in stop mode,
i m using domain user account on the member server ,and this account is member of administrator group on the member server local machine , does it matter? but pls note i have installed the acs with domain user account
Hello Ibrahim
Can you try to install acs software using domain-admin account on member server?
thanks
Devashree
