Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem with nac agent on ise 1.3
sara_elbahrawy
I have ise 1.3 running on SNS-3415
 I am running NAC agent on windows PC but the ise can't detect that the pc has a nac agent running and redirected it to unknown authorization profile
go2akram1
Had the same issue I upgraded, check the below link,
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus89119/?referring_site=bugquickviewredir
Venkatesh Attuluri
upgrading to ISE 2.0 must solve your isuse but let me know what is the NAC agent and NAD OS version  you are using
