Setting privilege level for logging into ASA through ACS
acharyr123
Level 3
Level 3
Hi!,
In my environment i implemented AAA for logging into switches, routers, asa etc through ACS which is being configured TACACS+.
I have set different privilege levels like readonly, readwrite etc into ACS. There are working fine when i try to login into switch or router.
But in ASA i am unable to restrict the privilege levels of different users.
Can someone plz guide me with ASA & ACS setting to solve this issue!!!!!
Hi!!
I tried this option. It is working fine with routers & switches. But for ASA privilege access it is not functioning.
I created 3 profiles in "Shared Profiles" & added 1 of them in Group setting & added users to this group with mentioning group authentication. This way i am able to control access to the switches & routers with proper privilege. But the same way when i tried to impolement ASA it's not happening.
Can u plz check it out...
What is the acs ver ? Did you try PIX Command Authorization instead of shell command author set ?
~JG
