SFTP / SCP using WinSCP error - help
rui.vieira1
Hi all -
I'm trying to access my ASA 5510 firewalls using WinSCP on SFTP (or SCP) protocol on port 22. I can authenticate (LOCAL database on AAA rules) but then can go no further as it throws an error message at me (pic attached).
I can SSH on port 22 (putty) successfully. Can also access it via the ASDM software.
This is all done inside the network on an IP address that has access rights to the ASA for management.
Hope one of you genius folks can help me resolve this cheeky pest of a problem.
Thanks in advance
nspasov
Are you trying to access the filesystem on the ASA? If yes, then I don't believe WinSCP is supported by ASA's due to the mechanics of how WinSCP works. Some of your other alternatives are:
- ASDM > Tools > File Management
- SecuireFX > SCP
- SCP on MAC/Linux
Thank you for rating helpful posts!
nspasov
- SecuireFX > SCP
- SCP on MAC/Linux
Thanks Neno - that's what I needed :)
Is it possible to backup the ASA by downloading the files on it, and in essence not requiring the use of a TFTP server at all?
Yes you can, go to ASDM > Tools > Backup > Check either all items to be backed up or only the desired ones. You can use the same menu then to later perform a restore.
