Two factor authentication using cisoc acs 5.2 & vasco
acharyr123
Level 3
Level 3
All our network devices are configured with TACACS+ with ACS 5.2; authentication, authorization & accounting is working fine. We were trying to integrate ACS with Vasco for 2 factor authentication using RADIUS. While integrating, i found that because of authorization commad enabled on the network devices, user authentication was not successfull. I removed the authorization commands from the switch & it worked.
I need authorization facility as well as 2 factor authentication. Can someone suggest me how to proceed with this plz !!!
camejia
Level 3
Level 3
When referring to "Two Factor Authentication" are you referring to two different password prompts?
Username:
Password:
OTP Password:
Or are you referring to:
Username:
OTP Password:
Also, did you change TACACS+ for RADIUS on the AAA Client (Network Device) configuration in order for it to communicate with the ACS server?
We will be waiting for your clarification.
Best Regards.
My devices are configured to support TACACS+ with ACS.
I am looking at:
Username:
Password: PIN + OTP
If I disable authorization in the switch, it works fine.
Rgds,
Partha
