04-07-2010 06:03 AM - edited 03-10-2019 05:03 PM
Hi all,
I seem to be getting lots of failed attemps in my logs that look below.. We have checked the particular device and theirs nothing plugged into it?
Any help would be great.. i have checked this post but there was no valid answer..
https://supportforums.cisco.com/message/852985#852985
Message-Type | User-Name | Caller-ID | Authen-Failure-Code | Author-Failure-Code | Author-Data | NAS-Port |
Authen failed | async | Invalid characters in username | tty0 | |||
Authen failed | @@ | async | Invalid characters in username | tty0 | ||
Authen failed | Y[@ | async | ACS user unknown | tty0 | ||
Authen failed | 2 | async | Invalid characters in username | tty0 | ||
Authen failed | $- | async | ACS user unknown | tty0 | ||
Authen failed | (XP | async | ACS user unknown | tty0 | ||
Authen failed | PB | async | ACS user unknown | tty0 | ||
Authen failed | @ | async | ACS user unknown | tty0 | ||
Authen failed | %% | async | ACS user unknown | tty0 | ||
Authen failed | I | async | ACS user unknown | tty0 | ||
Authen failed | $@ | async | ACS user unknown | tty0 | ||
Authen failed | #NAME? | async | ACS user unknown | tty0 | ||
Authen failed | Hm | async | ACS user unknown | tty0 | ||
Authen failed | Ii$ | async | Invalid characters in username | tty0 | ||
Authen failed | % | async | Invalid characters in username | tty0 | ||
Authen failed | !I$ | async | ACS user unknown | tty0 | ||
Authen failed | HI @ | async | ACS user unknown | tty0 | ||
Authen failed | [ | async | ACS user unknown | tty0 | ||
Authen failed | m Hm | async | Invalid characters in username | tty0 | ||
Authen failed | @[ | async | ACS user unknown | tty0 | ||
Authen failed | @ @mUL | async | ACS user unknown | tty0 | ||
04-07-2010 11:16 AM
Hi John,
Do we have any modem or terminal server connected to this device for out of band management? In these type of issues the problem is with the modem or term ser. It echo's back exec information from the console. The console interprets these message as login requests. This is extremely common. If that is the case then we need to reconfigure modem or term server, so that it does not echo.
If it's an IOS terminal server, the "no exec" command resolves the issue. If it is a modem, it must be reconfigured so that it no longer echoes.
~JG
Do rate helpful posts
