Using RAdius for Remote authentication but local for Telnet
wsherlock
I have a 3640 used for RAS. The remote users need a post dial terminal window for a form of token Authentication. This is specified with the LOGIN command. When I try and telnet in I am promted for username/password which passess but the telnet fails. The RADIUS server being used does not specify a telnet parameter, so tries to use PPP for telnet. If I remove Login RADIUS then the remote users get no output from thier post dial window. Can I specify that telnet is only locally authenticated, and therefore not effect any remote users needing to use login?
Any help would be greatly appreciated.
I have attached current config.
service password-encryption
service udp-small-servers
service tcp-small-servers
aaa new-model
aaa authentication login default group radius
aaa authentication ppp default if-needed group radius
aaa authorization exec default group radius
aaa authorization network default group radius
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
enable secret 5 $1$CMCO$IMo3eQ0NJO/l/yNfwdfOT0
ip subnet-zero
interface Ethernet0/1
ip address
no ip proxy-arp
full-duplex
interface Ethernet0/2
ip address
no ip proxy-arp
full-duplex
interface Ethernet0/3
ip address
ip address
ip helper-address
load-interval 30
full-duplex
interface Serial1/0
description 'Link to Warricker Centre'
ip address
priority-group 1
serial restart-delay 0
interface Serial1/1
description Link to Basement Upney Lane
ip address
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Group-Async1
ip unnumbered Ethernet0/3
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address dhcp
no fair-queue
ppp authentication chap
group-range 65 72
ip classless
ip http server
ip pim bidir-enable
priority-list 1 protocol ip high tcp telnet
dialer-list 1 protocol ip permit
radius-server host 15.10.30.4 auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7 0807697C3B38373E
line con 0
line 65 72
exec-timeout 0 0
modem InOut
transport preferred none
transport input all
transport output none
autoselect during-login
autoselect ppp
line aux 0
line vty 0 4
password 7 09435C081702124359
end
Georgia Coalman
Hi :)
You'll need to create a different method list for AAA that you can apply to your vty line. The term local means using a username/password that resides on your router. However looking at you configuration, you have no username/passwords configured so I assume that you want to simply get a password prompt when you telnet to the router. If I have understood you correctly then configure the following. As you haven't provided a show version I'm assuming that you're running the latest code:
aaa authentication login vtylines line none
aaa authorization exec vtylines none
line vty 0 4
login authentication vtylines
