Wireless Clients reauthentication fails when COA is sent by ISE
PSM
We have observed a strange issue in our network. For any reason(change in profile) when Cisco ISE send a COA and ask to reauthenticate to an connected client on wireless controller client session is interrupted. Client tries to reconnect and we see client connection is disrupted. If we see ISE logs for one of the such client, 1st event log says "Dynamic authorization succeeded" , in next "Authentication succeeded", in third event "Dynamic Authorization failed" and in 4th event "Dynamic Authorization succeeded" in 5th "Authentication succeeded"
It is EAP-TLS authentication and only Machine authentication is being performed.  This is a Win11 machine and has WIFI profile managed from Intune.
For us it looks WLC is not able to reauthenticate the client gracefully or Client it self does not handle reauthentication nicely.
 Anyone else here has this kind of observations ?  Is COA expected to be disruptive specially for Wireless clients ?
@PSM ,
 in ISE, at Operations > RADIUS > Live Logs, you see the following Events:
  • Dynamic Authorization Succeeded
  • Authentication Succeeded
  • Dynamic Authorization Failed
if you click the Details icon for the 3rd Event (Dynamic Authorization Failed) the likely Failure Reason is
11213 - No response received from Network Access Device after sending a Dynamic Authorization request
Am I correct ?
What appears in the Steps window ? Is there a timeout ?
Hope this helps !
PSM
@Marcelo Morais see details of one failure.
@PSM ,
  •  what is your ISE Release and Patch ?
  •  at Operations > RADIUS > Live Logs for this Endpoint:
  1. whenever you click the Refresh icon, will a new Time for the Status = blue icon appear ?
  2. Repeat Count is 0 and Session ID remains the same ?
  3. In the Details info for a Dynamic Authorization Succeeded (Event 5205), do you see a CoAReason = Change in Endpoint Identity Group/Policy/Logical Profile which are used in Authorization Policies ?
  4. In the Details info for a Dynamic Authorization Failed (Event 5417), do you see a CoAReason = Change in Endpoint Identity Group/Policy/Logical Profile which are used in Authorization Policies and an Error-Cause = Resources Unavailable ?
