what is the max thoughput of APeX?
yang.x.liu
if I run traffic between the Multi-Giga port of AP and one of 1G RJ45 ports of APeX, what is the expected thoughput? we are going to do some test which request over 90% data rate. I am interested if APeX and AP can support that data rate. during the test, we will not use radio interface of AP which will save some processing capacity of CPU on AP.
devangbh
Here are some results from DevTest team using IXIA based on 8.5 release:
Downstream (UDP) - ~950 Mbps
Upstream (UDP) - ~720 Mbps
PacketSize = 1370 Bytes
