10.4.3 Packet tracer- Basic device config
AJ21
Hey so I got a different topology than any example I've seen and almost had it done but I got stuck so if anyone can help it's appreciated. Here's the pkt I've been working on
which part of the configuration are you having problems with ? I see that some of the PCs have no IPv4 setting at all. What is the end goal, do you need IPv4 and IPv6 connectivity end to end ?
