10G interface license part code - ASR1001-X - throughput vs interface speed license difference?
Adam Shield
I currently have an ASR1001-X with 10G uplinks, albeit throughput is restricted to 2.5Gb.
The 'interface_10g' license is showing as Eval and I'm wanting to purchase the relevant license to allow a 10G interface, however I don't require 10G throughput (or at least for the immediate future).
Can someone kindly point me to the relevant license part code to allow a 10G interface, rather than throughput (if there is such a difference).
I found the below part codes, but it's unclear whether this is 10g interface or throughput.
FLSA1-1X-5-10G
Upgrade from 5 Gbps to 10 Gbps License for ASR 1001-X
FLSA1-1X-5-10G=
Upgrade from 5 Gbps to 10 Gbps Paper PAK for ASR 1001-X
L-FLA1-1X-5-10G=
Upgrade from 5 Gbps to 10 Gbps E-Deliver PAK for ASR 1001-X
XXX#show license
Index 33 Feature: interface_10g
Period left: 5 weeks 6 days
Period Used: 2 weeks 4 days
License Type: EvalRightToUse
License State: Active, In Use
License Count: 2/0 (In-use/Violation)
License Priority: Low
XXX#show platform hardware throughput level
The current throughput level is 2500000 kb/s
2 Accepted Solutions
Philip D'Ath
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/guide-c07-731639.html
However, if the ASR1001-X is upgraded to 20G, then the two built-in ports are automatically included.
The document also lists port based licences.
Cisco ASR1001-X IOS XE Software Activation Feature Licenses
FLSA1-BIN-1X10GE
ASR1001-X Built-in 10GE 1-port License
FLSA1-BIN-1X10GE=
5 Replies 5
Philip D'Ath
FLSA1-BIN-1X10GE
FLSA1-BIN-1X10GE=
Thanks Philip.
In summary, there are 'port only' licenses, separate to throughput, and assuming I'm utilizing both built-in 10Gb interfaces, I'll need both license codes above.
Lastly, the comment regarding "However, if the ASR1001-X is upgraded to 20G, then the two built-in ports are automatically included", I presume this is referring to 20Gb throughput license, which negates the need for the individual 10Gb port licenses.
That would be my expectation.
We have this:
Index 26 Feature: throughput_5g
Period left: Not Activated
Index 27 Feature: throughput_5g_to_10g
Index 28 Feature: throughput_5g_to_20g
Index 29 Feature: throughput_10g
Index 30 Feature: throughput_10g_to_20g
Index 31 Feature: throughput_20g
Period left: 5 weeks 1 day
Period Used: 3 weeks 2 days
Index 38 Feature: interface_10g_x2
AWS-DC-RTR#
So need 1 of each of these? So an interface speed setting is separate from the bandwidth it can pass?
What is the difference between these two?
FLSA1-BIN-1X10GE | ASR1001-X Built-in 10GE 1-port License
FLSA1-BIN-1X10GE= | ASR1001-X Built-in 10GE 1-port License
Or only 1 of these?
FLSA1-1X-2.5-20G | Upgrade from 2.5 Gbps to 20 Gbps License for ASR 1001-X
