2811 Router-QOS with BT RADMUX
fathar
Hi Guys,
I am connecting two WAN Sites A & B via 4Mb Metro ethernet connection. On Site A, FE0/0 is connected to Site B. FE0/1 is connected to user PC and F0/2 is connected to BT RADMUX Voice system which is communicating with another BT RADMUX at Site B. Now customer want to make sure that this 4mb BW is distributed evenly b/w PC at F0/2 and BT RADMUX at F0/3. What is the best qos strategy to use to guarentee 2MB BW for each connection? ALso please let me know if there is any special settings to be required on router for BT RADMUX VOice system as I am not able to get good quality voice at the moment.
Many Thanks
23 Replies 23
Good morning...
So are you experiencing poor voice comms at the moment ? From what I can see, there is no congestion on the link as such...
Paresh
It appears as if the router is not the issue here. You mentioned that there was a switch at the second site. There is a possibility that the switch is the issue here. What sort of switch is it ?
Paresh
Yeah Site B is using Cisco Swith 4506. BT Voice system is connected to one of FE port on this switch. The switch connects with SIte B Router, which is connected with SIte A router on F0/0 interface.
Cheers
Is there any chance you could post the switch config for those 2 ports ?
Also, is the voice perfectly clean with no data present ?
Paresh.
Hi Paresh,
Configs below as requested.Yes user claim that voice is clear when use alone.
Many thanks for your support.
Cheers
SITE B ROUTER:
interface GigabitEthernet0/3
desc 4 mb Metro ethernet to Site A
ip address..
no ip redirects
ip pim sparse-mode
duplex full
speed auto
service-policy output shaper
#sh policy-map interface gigabitEthernet 0/3
GigabitEthernet0/3
Service-policy output: Shaper
Class-map: class-default (match-any)
21498828 packets, 10955737425 bytes
5 minute offered rate 1173000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
4000000/4000000 25000 100000 100000 25 12500
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 21432631 2317875901 184786 127267321 no
Service-policy : PolOut
Class-map: RADMUX (match-all)
19689385 packets, 10356614450 bytes
5 minute offered rate 1036000 bps, drop rate 0 bps
Match: access-group 10
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 2000 (kbps) Burst 50000 (Bytes)
(pkts matched/bytes matched) 58682/30866732
(total drops/bytes drops) 0/0
1809443 packets, 599122975 bytes
5 minute offered rate 136000 bps, drop rate 0 bps
Match: any
SITE B SWITCH:
interface GigabitEthernet3/29
description **BT-RADMUX**
switchport access vlan 25
switchport mode access
speed 100
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
sh int g3/29
GigabitEthernet3/29 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0013.7fe8.f3ac (bia 0013.7fe8.f3
ac)
Description: **BT-RADMUX**
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 5w5d, output never, output hang never
Last clearing of "show interface" counters 00:26:38
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1040000 bits/sec, 237 packets/sec
5 minute output rate 1045000 bits/sec, 240 packets/sec
394336 packets input, 208927714 bytes, 0 no buffer
Received 25 broadcasts (0 multicast)
399665 packets output, 209390771 bytes, 0 underruns
0 lost carrier, 0 no carrier
SITE A Router :
interface FastEthernet0/0
desc 4 Mb Metro ethernet
ip address
ip pim sparse-mode
duplex full
speed auto
service-policy output Shaper
interface FastEthernet0/1
description **Data Lan **
ip address
ip pim sparse-mode
ip cgmp
duplex full
speed 100
interface FastEthernet0/0/0
desc **BT RADMUX*
duplex full
speed 100
interface Vlan25
ip address ...
# sh policy-map interface fastEthernet 0/0
FastEthernet0/0
18557222 packets, 9689119807 bytes
5 minute offered rate 1042000 bps, drop rate 0 bps
Match: any
Traffic Shaping
- 0 18557258 1099202372 121 91437 no
18387110 packets, 9671617800 bytes
Queueing
Strict Priority
(pkts matched/bytes matched) 49/25774
170112 packets, 17501481 bytes
5 minute offered rate 6000 bps, drop rate 0 bps
Match: any
Could you try changing the Shaper policy so that it looks like:
policy-map Shaper
class class-default
shape average 4000000 16000
service-policy PolOut
Paresh.
Its seems that everything is working fine with existing policy..ther was some problem in BT equipmetn which was causing noice problem and has been resolved..Thanks for all your help..you Deserved 5 :)
I'm happy to see that your problem has been resolved.
Paresh
