06-12-2013 01:27 PM
Does any one know which report will get me serial numbers of our 2911 routers using LMS 401?
TIA
06-18-2013 04:34 AM
Hi ,
Have you tried running the DETAIL DEVICE REPORT.
Go to Reports > Inventory > Detailed Device , you should see the Chassis serial no. there.
Afroz
06-18-2013 01:06 PM
Afroz,
Yes thats the first thing I did. However It gives lot of othe unwanted information.
LMS 32 & earlier used to provide Serial #s in particular.
