2950's and http authentication
dcooper_191
I'm deploying some 2950's with a crypto IOS 12.1.22.EA8a. Here is most of my config (that I think applies to my problem). I'm trying to let a user called "look" log in by http at level 1. However no matter what I've tried using the documents from ciso. I can't get it to work. It always pops up with LEVEL-15 login by default.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
username look password 0 xxxxx
username look privilege 1
(I've tried the ip http auth commands as well)
line vty 0 15
password xxxxx
line con 0
password xxxxx
login authentication default
Note the users work fine via SSH or Term.
Thank you for any suggestions.
ivillegas
Level 6
Level 6
You can configure username and password pairs, which are locally stored on the switch. These pairs are assigned to lines or interfaces and authenticate each user before that user can access the switch.Refer URL
http://cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a0080648d7f.html#wp1020693
