10-24-2006 06:24 AM
I meet the following problem :
I created a VLAN on my VTP domain with LMS. The action was done successfully but it cause a network crash during 10 minutes....
Someone met the same problem?
Thx
Angelique
10-24-2006 06:25 AM
If you had manually created the VLAN on the switch command line would it cause the same crash? Is the VLAN you added causing some issues with VTP, spanning tree, etc..?
10-24-2006 06:54 AM
No, when I create directly on the switch a VLAN it works without any crash, so it seems to be a LMS problem...
