Bookmark
Subscribe
3980
2960X -- Top talkers Cache is empty
faizanelahi
I have configured ip flow top talkers on 2960X switch like below
ip flow-top-talkers
top 10
sort by bytes
cache timeout 60000
And ingress/egress is applied to ports. But when i want to see the output...i get always CACHE IS EMPTY.
CEF is enabled. Above commands works perfectly on 871 router.
IOS version is c2960x-universalk9-mz.152-6.E1.bin
Please suggest whatelse needs to do to get it work.
Faizan.
Honestly, I searched in the feature navigator and the full command reference for 2960X but I couldn't find the support for that commands, the 2960X only supports Netflow Lite since 15.2(2)E, you could configure it and use a collector like PRTG (free until 100 sensors) in order to see the top-talkers, top-connections and top-protocols from your connections. https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_5_e/command_reference/b_1525e_consolidated_2960x_cr/b_1525e_consolidated_2960x_cr_chapter_0101.html
Please do not forget to rate useful post, this motivates us to continue participating in the community.
Best Regards,
6 Replies 6
Diana Karolina Rojas
Hello estimated!
Did you use this command "ip route-cache flow" in the same interfaces you are using the ip flow ingress and egress commands? Try this way and let me know If this could help you.
Please do not forget to rate useful post.
Best Regards,
Hi Diana,
Yes i did..please find the attached output for your reference...
Still same result "Cache is empty"
BR,
Faizan
Can you provide your "show ver" output?
Best Regards,
Best Regards,
Please find the attached output for sh ver.
Other than 2960x and 3560, on which layer 3 switch can i configure top talker for testing ??
I think you can run the Top-talkers in a 3750 with IP Services image.
Best Regards,
