06-04-2007 01:47 AM
We are ruuning 12.2(25)SEE2 on WS-C3750G-24TS. Can check if it support temperature value monitoring via SNMP? The following show command suggest that temperature value is not supported. Can someone confirmed this. If support, what is the OID to poll?
3750#show env all
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
3750#show env temperature status
Temperature Value: Not Supported
Temperature State: Not Supported
06-04-2007 01:51 AM
I tried to do the following but does not return anything:
snmpwalk -c public 1.1.1.1 .1.3.6.1.4.1.9.9.13.1.3.1.3
Look like WS-C3750G-24TS-S does not support snmp oid poll for temperature value. Not sure if new IOS version for WS-C3750G-24TS-S supported snmp OID temperature polling? Please advise.
06-04-2007 08:03 AM
This object, ciscoEnvMonTemperatureStatusValue is not supported on the 3750. You should poll chassisTempAlarm (1.3.6.1.4.1.9.5.1.2.13) from the CISCO-STACK-MIB to get the temperature indicator. If this returns off(1) then the switch is operating at normal temperature.
