3845 specific MIB/OID per T1 controller
Jim White
I have a Customer who is looking for a very specific SNMP MIB/OID.
System image file is "flash:c3845-ipvoicek9-mz.124-16.bin"
Would like OID which shows how many DS0s are in use on one particular controller.
Have tried these already and not specific per T1
CISCO-VOICE-DIAL-CONTROL-MIB:
"cvVoIPCallActiveTable"
"1.3.6.1.4.1.9.9.63.1.3.2"
Object cvVoIPCallActiveTable
OID 1.3.6.1.4.1.9.9.63.1.3.2
Object cvCallActiveDS0s
OID 1.3.6.1.4.1.9.9.63.1.3.3
DIAL-CONTROL-MIB:
"callActiveTable"
"1.3.6.1.2.1.10.21.1.3.1"
DIAL-CONTROL-MIB: "callActiveCallState"
"1.3.6.1.2.1.10.21.1.3.1.1.9"
Object callActiveCallState
OID 1.3.6.1.2.1.10.21.1.3.1.1.9
Any ideas would be appreciated.
Thank You.
Joe Clarke
The ideal object for this is cpmDS1ActiveDS0s from the CISCO-POP-MGMT-MIB. However, due to design conflicts between the MIB, and the ISR platforms, this object may not provide accurate results if the T1s have a three tuple index.
Thanks for the update.
Actually they are using that MIB and are having trouble getting good results. They do have the three tuple index as well.
Do you know of any other MIB I could have them try?
I do not believe there is another object which will give you what you want. However, if you can find a CLI command that gives the information, you may consider deploying the EEM custom MIB policy which can extract data from a CLI command, and create a custom MIB object using the EXPRESSION-MIB.
That policy can be downloaded from http://forums.cisco.com/eforum/servlet/EEM?page=eem&fn=script&scriptId=1743 .
