3850 management interface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-17-2018 02:26 PM - edited 03-01-2019 06:41 PM
I need to manage a 3850 stack on a different vrf from the default routing table. There is no support for vrf's in the license version I have but the management interface G0/0 is automatically in Mgmt-vrf. So I decided to apply my management address to that interface. However, I also need to manage some other L2 switches via the same range. So my thought was to take the 3850 management interface and connect it to a front port, g1/0/24, in vlan 100. I then trunk vlan 100 to the other switches and apply the only IP address they have to the vlan 100 SVI. When I try to ping the L2 switch from the management interface with ping vrf Mgmt-vrf it failed. Strangely the 3850 could resolve the L2 switch ip/mac and the L2 switch could resolve the 3850 management interface ip/mac but pings didn't work. When I looked at the arp table on the L2 switch and tried to find the mac address on the 3850 G1/0/24 it wasn't there. Remember, the L2 switch had correctly resolved the 3850 management IP but there was no entry for the mac address on any interface. Doing debugs and wireshark captures I could see the pings being returned to the correct IP and mac address but no ping replies came. As a last resort I decided to put a static mac entry on port G1/0/24 for the management interface and it started working.
So it seems the 3850 was failing to put the management interface mac on the port I had attached it to.
Does anyone know if this is a supported setup? I've managed to get it working but only with the static mac workaround.
As always, thanks for any input.
Stuart.
- Labels:
Network Management
