Quick Question
FashionNStyle
Hello everyone
I just upgraded my lab with nexus switch
I need to find out if I can UPLINK CISCO SG500-52 to NEXUS 3064-X to 5G trunk port with 5G speed
if possible with fiber optic transceiver
thank you
Ben Walters
Level 4
Level 4
Yes it is possible. 5Gbps SFP are supported on the model you have:
SG500-52
48GE + 4 GE (5G Stacking)
48 GE
2 combo GE + 2 1G/5G SFP
This is directly from the product data sheets found here:
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
I understand but what transceiver I have to use I tried with stack cable coax but it doesn't work at my home lab I used the stack cable connected to a 10Gtek Broadcom BCM57810S PCIe card to uplink my server to a SG500-52 switch but it didn't work Do you know Why? I told I can get 5G uplink might be wrong about that PCIe card because is SFP+ and this stack port is SFP Any advice ?
