3850 stack provision issue
Stupid-question
Community Member
I have a 2 member C3850 core stack, switch 1 is in provisioned state and is physically removed (not by me) switch 2 is the active switch. If I perform #no switch 1 provision will switch 2 renumber to switch 1 automatically when the first switch 1 disappears after the no switch command ?
#show switch detail
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 Provisioned
*2 Active 0c11.6784.b400 1 V06 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
2 DOWN DOWN None None
Assistance much appreciated.
John
2 Accepted Solutions
Leo Laohoo
No, switch renumbering command will need to be entered separately:
switch 2 renumber 1
And the switch will need to be rebooted to take effect.
Both commands, the "no switch 1 provision" and then the switch renumber, must be entered.
Once switch 2 reboots (and turns to switch 1), all config for switch 2 disappears.
Leo Laohoo
switch 2 renumber 1
Thanks Leo,
I have entries in the config for both switches, will the "no switch 1 provision" command take care if this or do I need to edit the config i.e. delete all the Gi1/0/1-24 ports and rename the Gi2/0/1-24 to Gi1/0/1-24 ports ?
Rgards
John
