Bookmark
Subscribe
27243
4510+R ssh error after upgrade xe 3.11.07 to xe 3.11.09
Hubert Kupper
after a upgrade from xe 3.11.07 to 3.11.09 we cannot open a ssh session to our 4510+R Switch. Before the upgrade everything works fine. The error message in the log  is:
%SSH-3-BAD_PACK_LEN: Bad packet lenghth
We zeroised the  rsa key and generate it new but the error still occours.
Any idea?
Regards, Hubert
Thanks for the update and confirmation.
 I have re-posted the EEM here to save people the time.
event manager applet KEX_ALGO
event syslog pattern "SSH-3-BAD_PACK_LEN"
 action 1.0 cli command "enable"
 action 2.0 cli command "conf t"
 action 3.0 cli command "ip ssh server algorithm kex diffie-hellman-group-exchange-sha1 diffie-hellman-group14-sha1"
 action 4.0 cli command "end"
Update (27 November 2023):  CSCwi02895
IMPORTANT:  The above EEM is a Workaround and should not be treated as a permanent "fix".
64 Replies 64
marce1000
 - Possibly your client does not support newer ciphers , examine with :
                           % nmap --script ssh2-enum-algos switch-hostname
   and compare with available ciphers on the client ,
  Linux ssh client (or perhaps others) also support verbose mode , which when enabled can also provide (similar) insights,
 M.
I compared the ciphers on the 4510 and my clients. They was the same as before.
No clients (ubuntu, windows, debian, etc.) work after the xe upgrade.
We won't go back to xe 3.11.07 because there are security issues.
Leo Laohoo
How big is the key, 2048?  4096?
Is SSHv2 enabled?
sshv2 is enabled the key size is 2048
Before we did the upgrade, we changed nothing in the configuration.
there are dual supervisor 8 modules in redundancy mode in the switch.
After fallback to 3.11.07 for testing without changing the config on switch or clients, ssh works again.
Solved: Re: SSH ISSUE %SSH-3-BAD_PACK_LEN: Bad packet length - Cisco Community
suggests to  check/upgrade your putty (or other ssh client) version
I used different clients on windows and linux an no one connects. When I downgrade to 3.11.07 all clients work fine.
Leo Laohoo
Post the complete output to the command "sh ssh".
Thanks to all for your answers. I'm out of office today. Tomorrow I post the output.
sh ssh
%No SSHv2 server connections running.
# sh ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): SSH-KEY
Modulus Size : 4096 bits
