4948e switches not sending vlan index OID
josephsmar1
I am having an issue were my 4948 switches are not sending the vlan index OID 1.3.6.1.2.1.17.7.1.4.2.1.2. Has anyone run into this and if so how can I fix it?
AFROJ AHMAD
Hi ,
share the below information:
-show version output
-snmpwalk on this OID "1.3.6.1.2.1.17.7.1.4.2.1.2"
Try the below OID "1.3.6.1.4.1.437.1.1.3.6.3.1.1" and see how it works for you
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Cisco IOS Software, Catalyst 4500 L3 Switch  Software (cat4500e-ENTSERVICESK9-M), Version 15.2(2)E2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 25-Mar-15 07:04 by prod_rel_team
ROM: 12.2(44r)SG9
System returned to ROM by reload
System restarted at 14:08:30 out Tue Jun 2 2015
System image file is "bootflash:/cat4500e-entservicesk9-mz.152-2.E2.bin"
Hobgoblin Revision 20, Fortooine Revision 1.40
I get no results for either one of those OIDs.
