5505 I need to add to (2) cisco 2960S sw's Need help w/ 5505 config
barryrosenhouse
I know zero about 5505 ASA's and my director tasked me with configuring and sending to off site location to add to the existing 2 cisco 2960S's. Can someone help me on how to config this 5505 so that it can be wired into those?
MichaelMcCoy
Good Morning barryrosenhouse,
I apologize I cannot answer your question, but reading the threads over the past couple years I do know that there's going to be more information needed for your question. Here are a few that I thought of?
How is it going to be configured? As an edge router? Or will it be behind your edge routers as far as an internal firewall of sorts?
Is there a DMVPN, or any type of VPN service that needs to be considered?
VOIP?
Michael,
not as an edge router, just firewall behind AT&T's edge router, there might be 1 voip phone attached.
marce1000
 - That is going to be difficult without some minimum knowledge of cisco's networking and equipment, I found a few resources : https://www.youtube.com/watch?v=F6qvKRFn-xc and https://www.youtube.com/watch?v=DmBa0W0-ANE
 M.
SUPPORT OUR CHANNEL BY DONATING-https://paypal.me/srvnewbie In brief, Cisco ASA is a security device that combines firewall, antivirus, intrusion prevention, and virtual private network (VPN) capabilities. It provides proactive threat defense that stops attacks before they spread through the ...
http://www.soundtraining.net/cisco-asa-training-101 In this Cisco ASA tutorial video, you will learn how to setup a Cisco ASA 5505 firewall using the ASDM (Adaptive Security Device Manager) Setup Wizard. You will also learn how to erase the startup configuration, restore the firewall to factory ...
Thanks Marce1000
