6500's and PI 2.2 snmpv3 Problems
Verschoor65
Hi Folks,
After an upgrade to PI 2.2 (from 2.1) my Catalyst 6509's and 6513's have a snmpv3 Issue.
They get managed when i add them to pi 2.2 but snmp inventory fails with
"Unable to collect the Flash and Image related information from the Device"
While all my 3560's ( with the same snmpv3 config) do not fail. (12.2(55)SE9)
It does not seem a compatability issue as i found that ios versions greater 12.2 are supported (running 12.2(33) SXi3 here).
Has anyone seen the same behaviour in PI 2.2, and is there a solution.
Thanx in advance
Frans Verschoor
AFROJ AHMAD
Hi Frans,
Go to Administration > System Settings > SNMP Settings
Increased the SNMP Timeout and RETRY ::
Reachability Retries     =3
Reachability Timeout  = 14
Then
delete and readdd the devive and see how it works
Thanks-
Afroz
****Ratings Encourages Contributors *****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Frans,
Then
Thanks-
Afroz
I had some trouble with PI 2.1 and i had not tinkered with the snmp time-outs in 2.2
it works now.
Frans
