a report about reachable devices in LMS report tools
ROMAN TOMASEK
                   Hi all,
is possible to display a report about reachable devices in DCR database? The report about unreachable devices is only in the reports menu in LMS 4.2.4 (Reports > Inventory > Management Status >Unreachable Devices).
I tried to use the report designer, but there is no possibility to create a rule for this report.:-( Similarly I tried to create group devices, but I didn't find some criteria for this type of group. Thanks.
Roman
5 Replies 5
AFROJ AHMAD
Hi Roman,
As per my knowledge , there is no such report available in LMS, however I would suggest you to create a POLLER for DEVICE AVAILBLITY  to achive your goal.
Go to  Monitor > Performance Settings > Setup > Pollers     >> click Create Poller.
check the below link for more information:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/lms_monitor/mnt-perf.html#wp1542387
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
thank you very much.
I know that I can create a poller, but it is not solution for a customer.:-( For example, the customer has a list of all devices and he wants to know which devices are reachable. For these devices he will generate a report about serial numbers.
Roman
Hi Roman,
It sad that my solution will not work for you, however I don't think there is any such report can be generated
Thanks-
Afroz
Hi Afroj,
thank you. It is bad info for me:-(
Roman
Hi Roman,
You can Open a TAC case and check if Development team can help you..
Thanks-
Afroz
