LMS 3.2 - Archive Purge
bm_5789
LMS 3.2 archive purge has not worked.  I have tried to run the job but purge for all devices fails.  Anyone know how or what I can do to jumpstart the purge?  TIA
AFROJ AHMAD
Hi ,
Archive purge can fail for many reasons. I can suggest few things , If it did not work. You can open up a TAC case for troubleshooting.
Try  this :
Increase the ConfigJobManager.heapsize as “1024m” in the following file:
NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/JobManager.properties  (ie,,ConfigJobManager.heapsize=1024m)  ·
Restart the daemon manager  ·
Once the daemon manager is started successfully,  Go to Admin > Network > Purge Settings > Config Archive Purge Settings,  increase the “Purge versions older than:” to 12 Months  (Also configure large value  for no. of versions that you would like to have per device) and trigger the job.  ·
Once job is completed, decrease the number of months gradually, until the desired no. of days & no. of versions required is reached.  This exercise is to reduce the number of archives loading in memory during a purge job, which will cause job hanging.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
