AAA Authentication methods
murray.bown
Frequent Visitor
Frequent Visitor
Hello Guys,
I looking for some clarity on AAA Authentication configuration.
Problem Statement
Using the configuration below, when i logon with a user account that is valid in the RADIUS server i am able to successfully SSH to the switch, if however i try to use a local account i am unable to authenticate, i can see the failed authentications in the RADIUS server logs.
My understanding is that the AAA configuration should try its first method and then if unsuccessful failover to local authentication.
Here is my config.
aaa group server radius RADIUS_GROUP
server name TEEIS0001
server name TEEIS0002
ip radius source-interface Vlan1
deadtime 5
aaa authentication login default group RADIUS_GROUP local
aaa authentication enable default enable
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
transport input ssh
transport output ssh
Mark Elsen
 - Check the reply from Kasrsten Iwen in this thread : https://community.cisco.com/t5/network-access-control/cisco-login-radius-and-local/td-p/2989344
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
